Need some help
Can any of these 18in woofers fit with these specs? If not I believe I can downgrade too the same style subwoofers except as a 15in. My planned tuning frequency would be 27 - 30hz
This is not intended to be a versus post. Please dont turn it into that.
35L X 21W X 19H
http://www.ficaraudio.com/product/q-series-q18neo/
http://www.ficaraudio.com/product/bl-series-bl18v3/
https://www.skaraudio.com/collections/zvx-series/products/zvx-18v2?variant=17690909889
http://www.dcsoundlab.com/level4
Its pretty unlikely you are going to have a enough space to run any of those subs properly.  What vehicle is this for and how much power are you going to be running?
Builds:
1 hour ago, Matthew Williams said:
Any ideas?
Run a 15" sub.
Builds:
You can run a a Sundown Zv3 18 which will work in very small airspace, you can also increase your box height, if you could manage to do 22H you could reach 5 net which would be minimum for those subs, also, finally you could opt for two 12s, I am sure two SP4 12s could do more damage than many single 18s.
45 minutes ago, Matthew Williams said:
Thats right I keep forgetting about that option. Two 12s have more surface area than a 15 if I remember correctly. Would it still work for how low I want to go?
Yup, should work fine.
Builds:
  • Who's Online   2 Members, 0 Anonymous, 745 Guests (See full list)
