Box design Dimensions: two P3D2 12" subs for 14Charger
RTCharger
Hi guys I'm new to this sight and am looking for optimal dimensions for two P3D2 12" subs, I have a RF prime 1200 watt Class D 1 Channel amp, 4 gauge wiring. I tried searching on existing forum conversations and could not locate a thread. I have a 2014 Dodge Charger RT.  If a thread for this had been created please point me in that direction. Thanks guys!
You should post ur dimensions of available space. Width/hight/depth.
My charger has a fold up section to get to the spare tire well, if ur car has that then maybe measure ur depth from behind the area that hindges up.
What is the recommendation on the RF site!?
Years ago,  I ran the older gray  (2) 12" p3's for a bit. Sealed enclosure. I think it was around 2 and a half cubes. I THINK. Ran a RF 1500bdcp, then a rf 2500 bdcp on them. I really liked it for what it was. Simple and sounded pretty ok. Doesn't the manual they come with or the website recommend volumes?
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 5175 Guests (See full list)
