moh.vze.com Posted March 18, 2017 Author Report Posted March 18, 2017 It was a bitch to solder these 12 gauge sundown wire onto the Image Dynamics speaker terminals. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Skullz Posted March 18, 2017 Report Posted March 18, 2017 First, always tin the terminals. Second, buy and use a high quality soldering iron that can get hot enough to do the job, otherwise use connectors. When you have gobs soldered like that, it will not hold and come off in time, when that happens it means your iron can't get the material hot enough to flow. EDIT: I always use a Weller iron. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
moh.vze.com Posted March 18, 2017 Author Report Posted March 18, 2017 My iron was on setting 3 out of 10. The wire itself was getting too hot for me to hold so I had to turn it down. This was what i was using: http://www.parts-express.com/variable-wattage-soldering-iron-0-50-watts--370-340 I think it's harder to solder 12 gauge wires onto these terminals because there are too many strands. I should have probably trimmed it down a bit. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Skullz Posted March 18, 2017 Report Posted March 18, 2017 Wire will always get hot, you want to use alligator clips, needle nose pliers or something else to hold it while you solder so you can get the material up to temp, if it does not come up to temp it will not flow and stick. It is a cold joint and will cause problems down the road. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ShadeTreeMechanic Posted March 18, 2017 Report Posted March 18, 2017 ^^^ and that black wire on the left speaker looks like it is a cold connection. I would heat it up so it can flow to the terminal. You really need a soldiering gun for connections that big. With a gun you can put the heat in quick enough that it won't melt the tinsel lead of the other end. Sometimes I will strip a length of scrap wire and take a single strand to wrap the connection to hold it in place while I use one hand for the iron and the other for the solider. Good looking set of speakers I wish I could hear them. that is a bad ass crossover too. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
moh.vze.com Posted March 18, 2017 Author Report Posted March 18, 2017 Hmm. Wouldn't the stock joints come apart if the speaker terminals get too hot? I was trying to solder it on without getting it too hot where it burns off the old joints where the tinsels connect DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Skullz Posted March 18, 2017 Report Posted March 18, 2017 High heat will allow you to solder it on fast enough to prevent the tinsel from heating and coming loose. This is one of those things you want to practice a bit. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
moh.vze.com Posted March 18, 2017 Author Report Posted March 18, 2017 Hmm. I didn't know SMD made solder guns https://www.walmart.com/ip/Pro-Tech-853D-SMD-DC-Power-3in1-Hot-Air-Iron-Gun-Rework-Soldering-Station-Welder-6-Gift/111981731?wmlspartner=wlpa&selectedSellerId=1994&adid=22222222227058476237&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=162983988181&wl4=pla-270450737450&wl5=9032951&wl6=&wl7=&wl8=&wl9=pla&wl10=113137381&wl11=online&wl12=111981731&wl13=&veh=sem DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Skullz Posted March 18, 2017 Report Posted March 18, 2017 lol, no 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ShadeTreeMechanic Posted March 18, 2017 Report Posted March 18, 2017 lol the SMD stands for surface mount device. That iron is too small any way. I still use my grandfathers Weller soldiering gun. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
