This isn't a Vs. thing, more like me asking to lean on your experience since I have no good way to really test these drivers, no where that I know of in MO carries these brands..
So I have my front doors and install finished and perfected, but my speakers are a little weakers than I would dance for, so I am using some tax monies to try to fix that prob and I want your allses helps! I run a 3 way active and have a mini DSP 6x8 on the way and a sub about to be installed, so consider it a 4-way active system I guess, and its in a single cab 2006 Silverado 1500 truck. I am currently running Jl audio CS200 2 way component tweeters and 6.5s (I am going to replace the tweeters soon too) and dayton audio 3s in the doors. I run midbass something like 125hz - 300hz, possibly as high as 600hz sometimes, I've been toying back and forth. The thump is ok, but I want it louder, with more power handling and more chest rattling thump, the closer I can get to take my breath away the better. I am running a Jl audio 360/2 to the midbass, but I am considering also getting an amp for the midbass that has 200w per channel and better signal to noise ratio, because the 360/2 kinda sucks there.
I am leaning towards a pair of CDT-ES06+s on a Jl audio rd400v3, but I want your suggestions!
My budget is something like 600 absolute max, 400 would be preferred.
Thanks in advance!
What are you getting for a sub setup? I would wait until it's running and maybe cross it over around 150hz. That might be what you are looking for.
Pioneer 80PRS
