The entire front half is got a bottom layer and idk how to make the roof solid without cutting the bottom sheet out
Maybe expanding foam between the layers? Drill a bunch of holes in the inside layer and squirt a little in each hole so the roof doesn't bulge.
Pioneer 80PRS
Will that make it solid? I'm wanting it to be completely solid so I'm thinking about just cutting it out but then I'll never be able to reinstall the overhead console
just pl glue or foam a couple peices of osb up there. you dont need to mirror the roof. just a few small peices of cheap osb, like quarter inch will solve your problem. I had 2 5x11 or so size pieces foamed up on my roof and it never moved. i know i wasnt that loud, or violent, but it held 56's on music all day. you dont need to completely cover the entire roof. just add some mass, in a couple short small peices and youll be amazed how it cures vibration. thats what id do for your build anyway. youll be able to lay the headliner right back in to..... like its not even there.....glue/foam them right in between the braces and your done. i used a jack. ... tossed some great stuff on the cut peice, jacked it up, had 4 beers, and did another peice and ran like that for 4 years..... headliner went back on like it wasnt even there and it did the trick...
That's the problem I have no way to get any wood any there , not even a way to push the board up yo get it solid
If I cut this bottom sheet out will it reduce the strength of the windows or roof causing it to be worse than it is. I could cut 2 windows out on both sides and put some mdf up in there, I got 3/4" mdf to work with and Pl adhesive, I should have plenty of clearance up front for 3/4 the back doesn't matter because it's getting walled soon
