No sound from Clarion EQS746
So I got this eq the other day, followed the directions wired up rcas from headunit(front) to the main in on the EQ. Have both rca from SAE 50.4 plugged into and my twisted sounds 1.3k. I've swapped around the RCAs, I'm getting 12v+ from the power/remote, pressed the aux button in and out...I'm starting to think this EQ will only work with a headunit with a single RCA connections? If I wire directly into the headunit to a front channel on the EQ I get sound but no control on the EQ itself. If anyone has this same EQ what's your setup like?
Cover the basics:
EQ turns on and lights up?
All HU controls/X-overs, etc. are set to OFF or Bypass?
HU volume is turned up enough to get a signal to the EQ?
AUX switch on front of EQ is in the correct position for the 'Main' input?
If none of the above, does it work if you use the HU RCA into the AUX input?
If the amp is a new install as well--are the gains turned all the way down and all X-overs turned off? Raise the gains a bit and see if you get any sound. Leave every other control OFF or Bypass and check the input selector switch if there is one.
Static drops are my bag.
YAYAYAYAYAYAYA I FIXED IT! Found out that when I used my dmm I was reading the remote wire(which was fine) and my power wire was no good! Thank baby Satan, I'm so damn happy now.
Id fix those power wires on the eq, thats a fire waiting to happen
X2 on that, this was only a test setup(explains messy wires as well) find it to be kind of scary how they're all so close together.
  • Who's Online   0 Members, 0 Anonymous, 4724 Guests (See full list)
