caraudionoob Posted April 19, 2017 Report Posted April 19, 2017 I have two SoundQubed HDC3.1 10's that I want to build a box for. I'd like some help with a box design. The max space I can work with is the following: height: 14 width: 39 top depth: 20 bottom depth: 25 It's going in a 2011 Mazda 6. I want to seal it off from the rest of the trunk. My electrical is Singer 370a, front battery: XS Power D1200, and rear batteries (2) XS Power D3400. Powering the subs will be two Hifonics BRX2400.1D. I want it tuned to ~33Hz. Any help will be greatly appreciated. Thank you!
caraudionoob Posted May 5, 2017 Author Report Posted May 5, 2017 So with the space that I have, I decided to go for dual 12's instead. I went to the SoundQubed DIY enclosure and figured out they recommend 2.2cubes net per 12" with ~16in of port per feet, which pretty much matches what AMI CUSTOMS' HDC3 & HDC4 Optimum Enclosure Size says. I ended up designing this in Torres. Can anyone give suggestions or comment if this is good enough?
Joe X Posted May 5, 2017 Report Posted May 5, 2017 You have a vertical turning slot port on a slanted box, this makes it more difficult to build than needed.
caraudionoob Posted May 5, 2017 Author Report Posted May 5, 2017 Thank you for replying, Joe. I have plenty of experience with woodwork. The construction process is not what I am concerned about. I just want to make sure that the design of the box is good.
ShadeTreeMechanic Posted May 6, 2017 Report Posted May 6, 2017 The design is going to be difficult too. In order to have a 26 inch port, part of it will have to go along the back wall if you want the port on the same side as your subs. On a box with one angled side, this will cause the port length to be uneven causing the port opening to be on an angle to compensate for the uneven length. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Triticum Agricolam Posted May 7, 2017 Report Posted May 7, 2017 11 hours ago, ShadeTreeMechanic said: The design is going to be difficult too. In order to have a 26 inch port, part of it will have to go along the back wall if you want the port on the same side as your subs. On a box with one angled side, this will cause the port length to be uneven causing the port opening to be on an angle to compensate for the uneven length. You can do it that way, with having the internal port opening angled, but you don't have to. You can leave the internal port mouth straight and just measure down the centerline of the port to get the effective length. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
caraudionoob Posted May 7, 2017 Author Report Posted May 7, 2017 Thanks to both of you for contributing! 4 minutes ago, Triticum Agricolam said: You can do it that way, with having the internal port opening angled, but you don't have to. You can leave the internal port mouth straight and just measure down the centerline of the port to get the effective length. Do you mean something like this? I went an initial 2.5" in for the port line to compensate for the 5" difference from top to bottom. Is that correct, or am I completely off?
Triticum Agricolam Posted May 7, 2017 Report Posted May 7, 2017 Yeah, that will work. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
caraudionoob Posted May 7, 2017 Author Report Posted May 7, 2017 3 minutes ago, Triticum Agricolam said: Yeah, that will work. Thanks for the input, much appreciated. With that design, will that give me the desired port area per foot, net volume, and tuning frequency that I had in the Torres calculator?
Triticum Agricolam Posted May 7, 2017 Report Posted May 7, 2017 31 minutes ago, caraudionoob said: Thanks for the input, much appreciated. With that design, will that give me the desired port area per foot, net volume, and tuning frequency that I had in the Torres calculator? Given the amount of power you are going to be running, I'd like to see more port area, like 90 sq in if you can make it work. I understand space is limited though, so compromises may have to be made. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
