Help Me for making ported enclosure box calculation
Sharan agm
Joe needs the T/S parameters to do what needs to be done. There should have been some paperwork that came inside the box with the sub.
Pioneer 80PRS
You will need to google or email JBL to get the T/S parameters.
I looked on the JBL website and didn't even find your sub listed. If you cant get them then the box you have will have to do. You could buy another pre fab box and take a chance on what it would sound like. You might be better off getting a better sub and then building a box for it because without the T/S parameters, building a box would just be a guess.
Here is the amount of information that is needed. This is For a SoundQubed sub and is only an example of what they would look like:
Model HDS212
Woofer Size 12"
F(s) 39.03
R(e) 7.43 Ohms
Z(max) 75.33 Ohms
Q(ms) 5.367
Q(es) 0.587
Q(ts) 0.529
V(as) 29.700 liters (1.049^ft)
L(e) 7.74 mH
n(0) 0.29%
M(ms) 201.90 grams
C(ms) 0.08 mm/N
Sensitivity 1W/1m 86.68 1W/1m
BL 25.03
Xmax 13.25mm
Magnet Weight 100oz
Coil Diameter 2.5"
Coil Length 38mm
Usable Throw 26.5mm
RMS Power 600W
Peak Power 1200W
Displacement .07^ft
Mounting Depth 7.0"
Circle Cutout 11.125"
Outer Diameter W/Gasket
12.5"
Pioneer 80PRS
Model HDS212
Woofer Size 12"
F(s) 39.03
R(e) 7.43 Ohms
Z(max) 75.33 Ohms
Q(ms) 5.367
Q(es) 0.587
Q(ts) 0.529
L(e) 7.74 mH
n(0) 0.29%
M(ms) 201.90 grams
C(ms) 0.08 mm/N
BL 25.03
Xmax 13.25mm
Magnet Weight 100oz
Coil Diameter 2.5"
Coil Length 38mm
Usable Throw 26.5mm
RMS Power 600W
Peak Power 1200W
Displacement .07^ft
Mounting Depth 7.0"
12.5"
Sir you only please help me to email jbl to get the T/S parameters
Inside the box the subwoofer came in. There should be some papers. Take pictures of them and post them here
05 TL build log SOLD
Model HDS212
Woofer Size 12"
F(s) 39.03
R(e) 7.43 Ohms
Z(max) 75.33 Ohms
Q(ms) 5.367
Q(es) 0.587
Q(ts) 0.529
L(e) 7.74 mH
n(0) 0.29%
M(ms) 201.90 grams
C(ms) 0.08 mm/N
BL 25.03
Xmax 13.25mm
Magnet Weight 100oz
Coil Diameter 2.5"
Coil Length 38mm
Usable Throw 26.5mm
RMS Power 600W
Peak Power 1200W
Displacement .07^ft
Mounting Depth 7.0"
12.5"
https://drive.google.com/folderview?id=0B56GVtRdg9RHeUdWWldRTXVkR3M uploaded sir
This is what they needed
Or you could build a box from what jbl recommends right there in the manual
1.75 cu.ft gross with a 4" round x 10" long port.
  • Who's Online   2 Members, 0 Anonymous, 1620 Guests (See full list)
