Sharan agm Posted April 29, 2017 Author Report Posted April 29, 2017 16 hours ago, Joe X said: You will need to find manufacturer driver specs/box specs for that sub. Waiting for your reply sir
ShadeTreeMechanic Posted April 29, 2017 Report Posted April 29, 2017 Joe needs the T/S parameters to do what needs to be done. There should have been some paperwork that came inside the box with the sub. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Sharan agm Posted April 29, 2017 Author Report Posted April 29, 2017 25 minutes ago, ShadeTreeMechanic said: Joe needs the T/S parameters to do what needs to be done. There should have been some paperwork that came inside the box with the sub. What came inside the box with sub, not getting your words
ShadeTreeMechanic Posted April 29, 2017 Report Posted April 29, 2017 You will need to google or email JBL to get the T/S parameters. I looked on the JBL website and didn't even find your sub listed. If you cant get them then the box you have will have to do. You could buy another pre fab box and take a chance on what it would sound like. You might be better off getting a better sub and then building a box for it because without the T/S parameters, building a box would just be a guess. Here is the amount of information that is needed. This is For a SoundQubed sub and is only an example of what they would look like: Model HDS212 Woofer Size 12" F(s) 39.03 R(e) 7.43 Ohms Z(max) 75.33 Ohms Q(ms) 5.367 Q(es) 0.587 Q(ts) 0.529 V(as) 29.700 liters (1.049^ft) L(e) 7.74 mH n(0) 0.29% M(ms) 201.90 grams C(ms) 0.08 mm/N Sensitivity 1W/1m 86.68 1W/1m BL 25.03 Xmax 13.25mm Magnet Weight 100oz Coil Diameter 2.5" Coil Length 38mm Usable Throw 26.5mm RMS Power 600W Peak Power 1200W Displacement .07^ft Mounting Depth 7.0" Circle Cutout 11.125" Outer Diameter W/Gasket 12.5" 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Sharan agm Posted April 29, 2017 Author Report Posted April 29, 2017 5 minutes ago, ShadeTreeMechanic said: You will need to google or email JBL to get the T/S parameters. I looked on the JBL website and didn't even find your sub listed. If you cant get them then the box you have will have to do. You could buy another pre fab box and take a chance on what it would sound like. You might be better off getting a better sub and then building a box for it because without the T/S parameters, building a box would just be a guess. Here is the amount of information that is needed. This is For a SoundQubed sub and is only an example of what they would look like: Model HDS212 Woofer Size 12" F(s) 39.03 R(e) 7.43 Ohms Z(max) 75.33 Ohms Q(ms) 5.367 Q(es) 0.587 Q(ts) 0.529 V(as) 29.700 liters (1.049^ft) L(e) 7.74 mH n(0) 0.29% M(ms) 201.90 grams C(ms) 0.08 mm/N Sensitivity 1W/1m 86.68 1W/1m BL 25.03 Xmax 13.25mm Magnet Weight 100oz Coil Diameter 2.5" Coil Length 38mm Usable Throw 26.5mm RMS Power 600W Peak Power 1200W Displacement .07^ft Mounting Depth 7.0" Circle Cutout 11.125" Outer Diameter W/Gasket 12.5" Sir you only please help me to email jbl to get the T/S parameters
YukonXL04 Posted April 29, 2017 Report Posted April 29, 2017 Inside the box the subwoofer came in. There should be some papers. Take pictures of them and post them here 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed
Sharan agm Posted April 29, 2017 Author Report Posted April 29, 2017 3 hours ago, ShadeTreeMechanic said: You will need to google or email JBL to get the T/S parameters. I looked on the JBL website and didn't even find your sub listed. If you cant get them then the box you have will have to do. You could buy another pre fab box and take a chance on what it would sound like. You might be better off getting a better sub and then building a box for it because without the T/S parameters, building a box would just be a guess. Here is the amount of information that is needed. This is For a SoundQubed sub and is only an example of what they would look like: Model HDS212 Woofer Size 12" F(s) 39.03 R(e) 7.43 Ohms Z(max) 75.33 Ohms Q(ms) 5.367 Q(es) 0.587 Q(ts) 0.529 V(as) 29.700 liters (1.049^ft) L(e) 7.74 mH n(0) 0.29% M(ms) 201.90 grams C(ms) 0.08 mm/N Sensitivity 1W/1m 86.68 1W/1m BL 25.03 Xmax 13.25mm Magnet Weight 100oz Coil Diameter 2.5" Coil Length 38mm Usable Throw 26.5mm RMS Power 600W Peak Power 1200W Displacement .07^ft Mounting Depth 7.0" Circle Cutout 11.125" Outer Diameter W/Gasket 12.5" https://drive.google.com/folderview?id=0B56GVtRdg9RHeUdWWldRTXVkR3M uploaded sir
Sharan agm Posted April 29, 2017 Author Report Posted April 29, 2017 On 4/28/2017 at 3:06 PM, Joe X said: You will need to find manufacturer driver specs/box specs for that sub. https://drive.google.com/folderview?id=0B56GVtRdg9RHeUdWWldRTXVkR3M Sir all specs are uploaded
Sharan agm Posted April 29, 2017 Author Report Posted April 29, 2017 1 hour ago, YukonXL04 said: Inside the box the subwoofer came in. There should be some papers. Take pictures of them and post them here https://drive.google.com/folderview?id=0B56GVtRdg9RHeUdWWldRTXVkR3M
YukonXL04 Posted April 29, 2017 Report Posted April 29, 2017 This is what they needed Or you could build a box from what jbl recommends right there in the manual 1.75 cu.ft gross with a 4" round x 10" long port. 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed
