obyrd1983 Posted June 16, 2017 Report Posted June 16, 2017 Ok first off I plan to run 2 sundown z12 v5 with 2 scv2000 scrapped together d3400 under the hood 240 amp mechman alt 2 d3400s in the back my question is with the batteries ran in parallel can i wire each amp to its own battery
obyrd1983 Posted June 17, 2017 Author Report Posted June 17, 2017 is there noone familiar with this or should i be in another farum
ShadeTreeMechanic Posted June 17, 2017 Report Posted June 17, 2017 You can because the batteries act like one big battery. (dejavu) 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
reedal Posted June 17, 2017 Report Posted June 17, 2017 4 hours ago, obyrd1983 said: is there noone familiar with this or should i be in another farum Give it time, people have lives and don't sit on here waiting for people to ask questions SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Kyblack76 Posted June 17, 2017 Report Posted June 17, 2017 If the bats are wired together, what would make you think you can't wire the amps to any hot in the circuit? That's like having a buss bar and asking if you need to use the same hole for every hot... In short, nice gear, and you'll be fine. Sorry I wasn't able to respond at midnight after my 14 hour shift at work. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
obyrd1983 Posted June 17, 2017 Author Report Posted June 17, 2017 thanks and sorry if I came off impatient
