Please help unsuck my ram
Spanka
12 minutes ago, slowfkncar said:
Okay i remember testing it once before, i might be a little off but it was something along the lines of Woofer 35-80hz / front doors 80-500hz / front dash 500hz^ / rear doors 35hz^
Also, forgive me when i speak of OEM integration i was referring to using an RF360.3 or any compatible multi-channel summing device with some ability to EQ his factory signals. Yes I've used them on amplified chryslers with pretty good results but nothing beats a new head unit lol. Look at the stereo harness, it's got power,ground,left spk,right spk and everything els is handled through the white-white/org (ignition,dimmer,amplifier,fader ect)
I have tried using the pac c2a-chy5 also but it still had fixed volume control. On a side note, the RF360.3 has its own volume control built into its control center knobs and can be used as volume if tapping the factory stereo pre-amp. It also has multiple inputs and can be selected with the knobs right at the control center.
Question: if i installed a typical head unit, and wanted to retain function of the stock mids/highs, would i be able to plug speaker outputs from the head unit into the harness and leave the orange-white/white wires disconnected? Would the DSP process that signal? If it did, i understand we could lose the fader and dimmer functions.
IG @walledsonic
Or maybe its just about time that i learned about addon DSPs.
IG @walledsonic
If you were to extend the factory unit wiring and hide it with the power,ground & can bus wires still connected then it should work. Once you disconnect the factory stereo it no longer sends a command to power up the amplifier. Your hidden factory unit will still be used for fader & balance but the volume can be left alone and used with the secondary unit.
Sorry guys, work got stressful and after work I wound down and fell asleep... I did however learn of something on the ram forums today!! I go pick mine up tomorrow I should have it installed by noon.
https://www.crutchfield.com/p_541AP4CH41/PAC-AmpPRO-AP4-CH41-Amplifier-Replacement-Interface.html?tp=6348&awkw=310832884250&awat=pla&awnw=g&awcr=194929759420&awdv=m&awug=9027638
That pac unit is awesome!! Was able to tune to 25 and 85!!
It is full volts all the way to 20hz and all the way up past 120!! The only way to go if you want to keep the factory head units. My problems are solved now to get this thing tuned in perfect.. thanks guys for your help.
Hey man, thats great news.  Were you able to plug the PAC back into your stock amp/DSP?  I was hoping to use just the sub output at this time without wiring extra amps up.
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 1006 Guests (See full list)
