olumpa Posted June 28, 2017 Report Posted June 28, 2017 I have a pair of DD M2C’s at .5 I am upgrading my stock battery from a deep cycle lead acid to something else. I will have a pair of 300a alts . My question is , I have been pondering the idea of 10 kinetic hc600-rev or 4 xs power 1800’s and last but not least a pair of NSB 480’s . Would there be a benifit to all the small batteries over less larger ones? With the amps I have would these be over kill or am I on point? thanks in advance
ShadeTreeMechanic Posted June 29, 2017 Report Posted June 29, 2017 A lot of people will run 100ah per 1000 watts. The only reason to run more smaller batteries would be to better fit the install. There really wouldn't be any benefit if you can fit big batteries. More smaller batteries need more connections. More connections mean a higher chance of a connection failing or going bad. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
olumpa Posted June 29, 2017 Author Report Posted June 29, 2017 Would a pair of NSB 400’s be enough for my setup or would I need the 480’s? thabks for the info on the multiple batts I think I will stick with simplistic just need to figure out how many budget is kinda tight, also open to suggestions on batteries for the setup. Thanks again
8ten8 Posted July 3, 2017 Report Posted July 3, 2017 On 6/29/2017 at 7:50 AM, olumpa said: Would a pair of NSB 400’s be enough for my setup or would I need the 480’s? thabks for the info on the multiple batts I think I will stick with simplistic just need to figure out how many budget is kinda tight, also open to suggestions on batteries for the setup. Thanks again If you can afford the 480's $ and the weight, go for it. NS is get stuff. GP has a sale going on for the 4th of July. http://gpcaraudio.com/bundle-2-northstar-smsagm480-w-gp52-terminals-noco-g26000-charger/
rockFord_Expedition Posted July 5, 2017 Report Posted July 5, 2017 XS Power has a wattage guide on their website. Here is a link Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
