Box design help for 1 12.2 HCCA
Hey guys, looking for some help on designing a box for an HCCA 12.2. It will be running off of a SAZ-3500 in a 2012 Malibu. Want to do rear facing sub and port. This is a daily setup and I'm fine with anywhere in the 32-38 HZ range.
Max dimensions:
20" Deep
32" Wide
13.5" Tall
Your going to have to bring airspace down, and bring port area and length up. Not sure of that exact sub. But 2.71 for a 12 seems like alot
05 TL build log SOLD
Due to your space limitation and the large amount of power you are running, you probably aren't going to be able to fit enough port area to make everything perfect.  You just have to do the best you can and accept that you are going to get some port compression and noise.  It is what it is.  I agree with YukonXLs suggestion of shrinking down the net volume a bit to make room for more port.
Builds:
If flared on both ends, you might be alright with that. I have 2 flared 6" aero's on my 7cube box with 2k going to it. DD 9518
You will need about twice as much port. a lot of it depends on the power.
Pioneer 80PRS
That's what I would do.
I'd try 2 (max 2.5) cu Feet : that should be enough.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
  • Who's Online   0 Members, 0 Anonymous, 275 Guests (See full list)
