Wehan Posted July 30, 2017 Report Posted July 30, 2017 I already have a pair of FI SSD 12's, they are fully loaded high QTS (it's still a low enough QTS for a ported enclosure to be just fine) and I have a Behringer iNuke NU3000dsp. I have the subs currently in sealed 1cuft enclosures but the output is not very good. My question: Can the pair of 12's be a viable large single ported box canadates or am I better off going to say the Dayton Ultimax 18 and a Marty sub enclosure variant like a large number of DIY builders seem to doing?
Triticum Agricolam Posted July 30, 2017 Report Posted July 30, 2017 They will work and you should be able to get decent performance. However depending on how low you want good output to a purpose built home theater sub is going to do better. Especially if you go up to an 18". "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Triticum Agricolam Posted July 30, 2017 Report Posted July 30, 2017 If you have space for a Marty, it's going to crush those SSDs below 30 Hz. Above 30 Hz their performance will be closer. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Wehan Posted July 30, 2017 Author Report Posted July 30, 2017 2 minutes ago, Triticum Agricolam said: If you have space for a Marty, it's going to crush those SSDs below 30 Hz. Above 30 Hz their performance will be closer. I was really hoping you would chime in, with any luck I can get enough out of selling the SSD'S to pay for an 18 and Marty building materials, I am after the super lows Marty's are known for. I definitely have room for a full Marty and I might even get the wife to go along if it doesn't cost anything.
Triticum Agricolam Posted July 31, 2017 Report Posted July 31, 2017 3 hours ago, Wehan said: I was really hoping you would chime in, with any luck I can get enough out of selling the SSD'S to pay for an 18 and Marty building materials, I am after the super lows Marty's are known for. I definitely have room for a full Marty and I might even get the wife to go along if it doesn't cost anything. If you have the space and spousal approval for a full Marty, you should totally do it. The SSD's would be great for music, but for home theater bass the Marty is the way to go! "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ShadeTreeMechanic Posted July 31, 2017 Report Posted July 31, 2017 Now I have to Google Marty. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
twalker182 Posted July 31, 2017 Report Posted July 31, 2017 You can also search for "things that look like a big ass storage chest and/or bench". 2010 Accord Sedan XS D3400R Clarion HU Sundown mids and highs Incriminator amps Incriminator Lethal Injection 12"
Wehan Posted July 31, 2017 Author Report Posted July 31, 2017 13 minutes ago, twalker182 said: You can also search for "things that look like a big ass storage chest and/or bench". That shake your trim off and put out 15Hz on 1krms.
