mike12 Posted August 13, 2017 Report Posted August 13, 2017 So Its upgrade time and I plan on running 2 ascendant audio chaos 12s out of a trunk with the trunk being sealed, i would like to have the subs firing the same side as the port into the cab with the port centered between subs. Im looking for something with 4 cubes not including the displacements. tuned to 32 hz with 64" of port area and a 1.5" baffle i plan on using 1/2" allthread for bracing so it wont be an issue in taking up air space. Ive come up with a few designs but they dont work out, i need the box to be 34" wide with the height being 15" the depth cannot be greater than 26" thanks for the help!!! Also will be running on rated power
Triticum Agricolam Posted August 13, 2017 Report Posted August 13, 2017 How much power are you going to be running? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
mike12 Posted August 13, 2017 Author Report Posted August 13, 2017 Ampere audio 2k on 180ah of batts and good electrical
