350 Volt Car Audio Lithium Battery First Impression
High Voltage Lithium Initial thoughts and overview.
1 350 volt Michigan Solar Energy High Voltage lithium battery.
1 Taramps T60K wired at .5
Starting voltage: 307
Final Voltage drop: 266
~220vac 92 amps output
~266vdc 82.7 amps output
92% efficient
20,000 watts rising to 2.4 ohms clamped.
The battery FYI is 6ah. Cost between 3-5 grand. Weighs 60 pounds. And the amp is $1700.
307v is less than 20% charge.
Battery is 1.8kwh.
1c rate is 1,800w for 1 hour
2c rate is 3,600w for 30 min
4c rate is 7,200w for 15 min
So far, I'm extremely estatic about the results and the future possibilities using these technologies together. Just think, you can literally burp 20,000 watts, out the trunk of a BMW or smart car haha.
Where this cost would be justifiable, would be for applications that requires a lot of power, low weight, and space savings. This battery is only 27"x17"x4". So the power density per space is truly unmatched. I will be posting more of my findings, so stay tuned. Also, you can add as many as you want in parallel to get some really stupid power levels.
*BONUS*
The excursion did a 157.x outlaw @ 41hz wit that 20k. So I'm really excited about that! Rayshawn Lawrence built the enclosure.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
Link works bruh.
Innovative setup!  Looking forward to more info.
IG @walledsonic
Fixed it.
Pioneer 80PRS
Awesome stuff! How often do you have to charge it up?
Pioneer 80PRS
  • 4 weeks later...
  • Who's Online   1 Member, 0 Anonymous, 773 Guests (See full list)
