Stephen616 Posted August 28, 2017 Report Posted August 28, 2017 i have a 2012 Chrysler 200 with a small trunk I have 2 15" power acoustic mofo-152x they call for 3sqft of volume each so I built a 6 sqft box but I want to put 2 more but cant make the box any bigger. I have room to place 2 more on the top but don't how that would work or if I can without damaging the subs or what options I have if any.
fmedina Posted August 29, 2017 Report Posted August 29, 2017 9 minutes ago, Stephen616 said: i have a 2012 Chrysler 200 with a small trunk I have 2 15" power acoustic mofo-152x they call for 3sqft of volume each so I built a 6 sqft box but I want to put 2 more but cant make the box any bigger. I have room to place 2 more on the top but don't how that would work or if I can without damaging the subs or what options I have if any. if theres no room then theres no room man. i you cant fit a 12cu ft enclosure for four 15s after all displacements then a partial wall might be necessary. i wouldnt cram them in a too small of a box. how much more room exactly do you have. give us max dimensions you have to work with.
ShadeTreeMechanic Posted August 29, 2017 Report Posted August 29, 2017 Two subs in the right box will probably be louder than four subs in the wrong box. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Ron36 Posted August 29, 2017 Report Posted August 29, 2017 You could probably squeez 4 tens in there but no way 15's, 4 Sundown ZV5-10's would be killer 1.5ft3 per sub. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Stephen616 Posted August 31, 2017 Author Report Posted August 31, 2017 the max dimensions I got are 32 x 36 x 16 which is 8.8ft3 the 2 I have in there sound good but was wanting to get louder sounds great inside but not loud or hard enough lol always want more I might have to just play with the 2 I got in different boxes
