I really need one of these tools for my bay. @meade916 Whats the big difference? I watched both videos on the how to use the DD1 and DD1 plus and i see the Digital display is a plus and to set the overlap, is there anything else different?
https://damore-engineering.myshopify.com/products/dd-2
Check out the feature listed here and compare with the DD-1.
IG @walledsonic
The DD-1+ has the following additional features that the original DD-1 doesn't have....
  • Sets audio system gain overlap, continuously variable from 0.0dB - 15.0dB in 0.1dB steps
  • Checks gain overlap of an audio system without making any adjustments to the existing settings
  • Verifies that the gain overlap of an install hasn't been tampered with after install
  • Features our Patent Pending Distortion Detection system plus digital microcontroller and our proprietary firmware
  • 200V maximum input (same as DD-1 HV)
  • Quasi-RMS voltmeter (can detect clipping at any frequency)
DD-1+: https://www.wccaraudio.com/smd-distortion-detector-plus-dd-1.html
DD-1: https://www.wccaraudio.com/smd-distortion-detector-dd-36.htm
