akuma4u Posted December 15, 2017 Report Posted December 15, 2017 pardon my crappy math skills,.. but how do you calculate the radius of a slot port? lets say for example 12 inches tall x 2.75 inches wide? what would the radius be? i need to figure out how to do radius calculations in order to figure out port velocity using this calculator http://www.carstereo.com/help/Articles.cfm?id=4
Markous Posted December 15, 2017 Report Posted December 15, 2017 You wouldn't be calculating radius (thats just for circles) just area by multiplying height times width. Which in your case would be 33 inches square. edit - That would be the equivalent of a 6.5" diameter round port if i did the math right '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
WalledSonic Posted December 15, 2017 Report Posted December 15, 2017 You mean like a 90 degree bend around the edge of the box? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
akuma4u Posted December 15, 2017 Author Report Posted December 15, 2017 the link i provided with the calculator, is that only for aero ports? or can that be used for slot ports? if so ,. what do i enter in the area where it says radius?
akuma4u Posted December 15, 2017 Author Report Posted December 15, 2017 i have several designs which i need figuring out the port velocity on to make sure its under 7-8% ... but i dont know how.. can someone help me out?
WalledSonic Posted December 15, 2017 Report Posted December 15, 2017 So take your H x W dimension, then divide it by pi, then take the square root of that. That will be effective radius. Example: 4" x 8" port = 32 sq inches area (pi) x R^2 = area (pi) = 3.14159 32/3.14159 = 10.186. Take the square root. That equals 3.192. Use R = 3.192 for this example. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Markous Posted December 15, 2017 Report Posted December 15, 2017 The difference in surface area wouldn't allow you to use that same number in that particular calculation though would it Walled? '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
WalledSonic Posted December 15, 2017 Report Posted December 15, 2017 5 minutes ago, Markous said: The difference in surface area wouldn't allow you to use that same number in that particular calculation though would it Walled? No, but the calculation isnt gonna net you an exact response in the first place. At least OP can be consistent. The difference in drag shouldnt change tuning more than a frequency or two, I'd imagine. Term pro software said my design tuning was 33Hz. Its actually 26Hz. So even software wont get you exactly where you need to be. EDIT: I know OP is talking port velocity, but same thing goes. Its not gonna be exact, especially with different power levels. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
akuma4u Posted December 15, 2017 Author Report Posted December 15, 2017 walledsonic: using your explanation (thanks) i entered in my port h x w.. 12 x 2.75 and in the end i got 2.87 for the radius.. i entered this into the calculator and i got the answer: 2.13 percentage of mach now this is under the 7-8% number i was told to keep it under , so this should be fine right? OR should the answer read .8 or less?
WalledSonic Posted December 15, 2017 Report Posted December 15, 2017 Dont know if this will help Akuma. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
