So I blew my Rockford p3 in about 20 seconds.
Sounds like no one in my city has Rockford. So leaning towards a soundqubed hdc3 or hdc4.  I just built a box tuned at 32hz @2.66 cubic feet. You think the box could support that for a lil while till I build a new one.  I’ve owned sundown x’s before and was really happy with those. Not very sure on how the hdc’s compare to sundowns x series. But for the price it seems like a deal.
I figure I have enough box room for 2 15s eventually. So either 2 hdc3’s or hdc4s. On a 3500 amp. And can add another 3500 later.
looking for some input on the matter
How did you blow the sub?
IG @walledsonic
28 minutes ago, Sky said:
To much power I’m assuming. I kept it low from what I thought it could take.  Apparently not the case.
Which amp?
IG @walledsonic
I would figure out how you blew the first sub so you dont have it happen again. If you think the power was low then you mught have been clipping the signal. that will blow a sub even if running lower than rated power to it.
The 3 things you need to consider when fitting a sub to an enclosure is volume of enclosure, power you are running, and port area. If you are going to be running 3500 watts to it it will need a hella big port.
