19 minutes ago, ToNasty said:
Watch your voltage level then. You could burn something up
How high?  I skipped my current sensor at one point for 2 months and it charged great... 14.2ish.  Not a Silverado, but still a 2015 Chevy PCM.
IG @walledsonic
I'm not running a lot a power yet just the 4channel. But I haven't been using a volt meter just the cluster gauge and it seems it still working fine. It fluctuates the same as before I started messing with anything. When I get the sub amp I have the smd volt meter that I'll be using.
GM's RVC (Regulated Voltage Control AKA PCM) system sends alert signal to the dash when voltage exceeds 15.5V.  If its lower than 15.5, no problem.  if its over that, you'll be alerted by the light on your dash.
IG @walledsonic
Im going to velcro the vm where the trailer brake controller is. I took the controller out and stuffed it behind the panel. I dont own a trailer and I think I will never have to use it but if it ever came up it would be ready to use. All I would have to do is pull the panel out and set it where I need it.
Chimpo is on the board too, right above the D'Amore logo at the top
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 1497 Guests (See full list)
