Sub enclosure help
vroom
it helps, but it's like putting a little bandaid on a big boo-boo. you'd be better with a single 15 over two 12's, if you haven't already bought the subs. a 15 slightly overpowered at 3 cubes should perform better than squeezing two 12's in there, which is what would end up happening if we actually designed/calculated an enclosure using your available dimensions
On 5/5/2018 at 11:12 PM, vroom said:
I can also maybe squeeze the box to 53x14.5x14.5 which should be right on 5 cubic feet gross
What is the vehicle?
5 hours ago, vroom said:
Its a 91 toyota pickup extra cab 4x4
Locating you box on the rear seat area you can do it as tall as you'd like, why wouldn't you go taller than 14.5?
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
