Sundown SA 10s
Daddy_
Joe x boxes are on point.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
10 hours ago, Daddy_ said:
Is 2.2 net cubes ok. Dont the SA 10s need 1.25 per woofer so 2.5 total? I also decided that 32hertz might to low and I would never play that low so instead could you do 34 hertz? Also what if I gave them 1.5 per woofer and 3 cubes total what is the difference between 2.5 and 3 cubes Id hear?
Those are recommended 1.0 - 1.25, if you go larger it will get a little louder and a little less nice sounding, now you need to get the box in not just have the space, I always recommend to build a cardboard box to see if it will get in or not.
Do you have the 3d model with cut outs? Sorry didnt see nee post's
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
Unfortunately lap top is down rt now. I used Torres on a friend's for those specs. I can give a detailed description though. Piece for piece. Joe x box is excellent btw. I build mine a little different but his should sound excellent.
On 6/9/2018 at 4:47 PM, Mack187Murder said:
Curious as to why more people dont do one chamber ported and one chamber sealed to get a broader range out of their subs?
They do... It's called a fourth order bandpass box
So here is a suggestion reflecting the changes you wanted, it's larger so make sure you can get it inside, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
I'm getting 2.6 @35.49 hz with 45in² Port area and 17.46in² per foot... Port too big in my opinion.
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
