Requesting dual Sundown X8 box help
Vexser
Gentleman... yes the thing has impedance rise and that was got me lookin at .5" materials for some parts to find volume... (less than 2000 watts)
If braced well and constructed correctly... I think it will be just fine...
Granted, this thing is a swiss watch but I believe it'll be fine and the added volume and port area will be worth it in the end
here it is annotated completely...
Like I said... lol... swiss watch time.
Should be ok IMO
Sho is pretty... imagine the cost and added strength if some lexan was used. .5" Lexan for the top and maybe second port wall, .75" Lexan for the baffle
Now that's one intricate SOB
Impedance rise won't be too much of an issue with 2 8's imo. I know the x8's can move but I don't understand the concern. Also, what correlation does material thickness have to do with impedance rise?
Huh?.. you got me confused... I'm sorry, thickness of material has NO relation to impedance rise. The enclosure as drawn if it's constructed well will do fine IMHO.
The rise will be probably more than you think man... 2K turned into considerably less when modeled up but I still tried to account for power with more port area. All I could do turned out to be a collection of compromises with a slot. The final result should turn out pretty good IMHO.
Just seems like a lot of extra bracing when ¾" material would help tremendously. Jmo.
That's a by product of finding sufficient port area for his power along with some decent volume... it IS 2K of input on a pair of 750 watt drivers... so I did my best accommodating both and found a pretty good balance.
Yes.. it's intricate... a swiss watch so to speak, and still a collection of compromises but should allow those X's to open up and put out better than 14in2^ft3 in 1.5ft3 net.
Tryin' to accommodate all factors made this a challenge... and I like challenges... lol
By no means a perfect solution IMO but a pretty good result I think.
And ya'... .75" all around is best, add a double baffle also, even braced as well.. but the space given along with the input power is what got me interested and lookin' at alternatives, it was definitely a project.
My bad. I was thinking box flex would cause strange impedence rises, essentially reducing the power being applied to the sub as it would change the tuning of the box slightly. Guess I should just be more worried about the acoustic power loss. Either way, box flex is bad for output.
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Church.... hence the bracing, it would be a mutha' to assemble as I drew it... definitely NOT for the beginner... lol
  • Who's Online   1 Member, 0 Anonymous, 324 Guests (See full list)
