Fuse size
Bro for 12 k youll need alot more than 2 batts and 1 alt. Your talking at least 4 batts and two high output alts with multiple 0 gauge ofc runs of neg and pos front to back and even then your gonna get low voltage with a few mins of full tilt. Not to mention mids highs amps and sound deading. Whats all this going in? Wat u using it for? Burps? Demo? Competing? Wat woofers you running?
7 hours ago, violntshags said:
sorry I asked for help. Fuck you assholes
People try and help you and you go off like this wow. all you had to do was type in the amp in a search engine like I just did and got all this nifty info!
TECHNICAL SPECIFICATIONS
  • 12000.1D 1Ω
  • Power @ 12.6V @ 1Ω: 1 x 12000 W RMS
  • Power @ 12.6V @ 2Ω: 1 x 6600 W RMS
  • Power @ 12.6V @ 4Ω: 1 x 3630 W RMS
  • Power @ 14.4V @ 1Ω: 1 x 15672 W RMS
  • Power @ 14.4V @ 2Ω: 1 x 8620 W RMS
  • Power @ 14.4V @ 4Ω: 1 x 4741 W RMS
  • Operating Voltage: 9V - 16V
  • Current Draw (Music): 627A
  • Current Draw (Max): 1253A
  • THD + N - (10% Rated Power): 0.09%
  • Damping Factor: >1000
  • SNR: 74dB
  • Frequency Response: 5 Hz – 20 kHz
  • Crossover HPF: 5 Hz – 80 Hz
  • Crossover LPF: 80 Hz – 20 kHz
  • Bass Boost: 0 – 12dB
  • Bass Boost Range 35Hz – 55Hz
  • Recommend Fuse: 3 x 225A (Music) / 3 x 500A (SPL)
73456w9vbwevsdb
sodtbsorutnvsd
sdtuspdun sd d
f gsdfiusd gdf n
1 hour ago, violntshags said:
SounDigital SD12000.1D EVO II 2018 1 ohms
Google search had this to say on an eBay listing info section:
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=253117356769&category=18795&pm=1&ds=0&t=1527173182000&ver=0&cspheader=1
12000.1D 1Ω
Power @ 12.6V @ 4Ω: 1 x 3633 W RMS
Power @ 14.4V @ 1Ω: 1x 15672 W RMS
Working Voltage: 9V - 16V
Consumption in Musical Program: 627A
Maximum Power Consumption: 1253A
Recommended fuse: 3 x 225A
According to this you should be using three inputs, each fused 225 A.
Now 0 gauge ofc is good for 300 A but in this instance if you were to run three runs into the amp you could use CCA if you wanted to but I find that limits your ability to upgrade in the future.
My suggestion is to put at least two runs of 0 gauge ofc, each fused 300 A, preferrably three runs for any spikes in draw. I'm not sure if the maximum power consumption is a highly biased number or if that's really likely to draw that much. Regardless, make sure you put this amp somewhere you can cool it cause it's gonna be toasty.
Good luck man
  • 12000.1D 1Ω
  • SNR: 74dB
You beat me to it dang nabbit ?
  • Who's Online   0 Members, 0 Anonymous, 1643 Guests (See full list)
