Fuse size
Hey peeps, I’m installing a 12k amp for two 18’s at 1 ohm. Have no clue what size fuse I should use off the battery. I’ve been reading it should be what the amp draw is. That would make it like a 650 amp fuse.. any help would be appreciated
If you're serious... 300 amps for 0ga OFC is recommended. I'm a little concerned about "the battery" bit though. You running lithium or something?
Lol.
Need to know who this is so I can find him on youtube in a month and see his car burned to the ground.
2007 Pacifica
@violntshags What is the amp model? If it is a 12k amp it likely has multiple pos/neg inputs I'd hope, so you could split up the load between runs, so two runs of 1/0 ofc would get you about 600 A total (300 per). The manufacturer will have specifications on what size fuse to use, so I'd suggest running what that calls for. If it is 650 A then you may need to use 2/0 ofc which can hold about 400 A according to the post I always refer to:
4 hours ago, violntshags said:
sorry I asked for help. Fuck you assholes
Please accept my sincerest apologies for my inadequate help. Perhaps instead of me, you could substitute a fire extinguisher!
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
