Dual subs wired in series
BigChief247
1 hour ago, BigChief247 said:
Since I never see this configuration suggested, I'm assuming it's not recommended, but can someone tell me what the problem would be with it.  Also what ohm load would it produce using dual 4 ohm subs?series_sub.png
Generally isn’t used b/c w/4 ohm subs would result in an 8 ohm load. So would decrease power output.
it's not done b/c the loads is so high you'll get little to no output from your amp. the example you give of a pair of dual 4 ohm subs would yield a 16 ohm load. let's say you have an amp that does 1000 @ 1 ohm. at 16 ohms that amp will likely only produce around 60 watts.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • Who's Online   0 Members, 0 Anonymous, 1081 Guests (See full list)
