BassMunky Posted October 7, 2018 Report Share Posted October 7, 2018 Doing recone. Got most of the glue off top and bottom. How do I get the rest off? Wire wheel didn't work do I go with a grinder or sandpaper? Any suggestions to get it super clean? I chiseled most of it off. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
bmwking Posted October 7, 2018 Report Share Posted October 7, 2018 if youre trying to remove the leftover glue from the bare basket, a flapper disc on an angle grinder works really quickly. it's all about holding it at the right angle and making sure you get in there without the tool yanking out of your hand. dont dig into the metal so have a delicate but steady touch. Link to comment Share on other sites More sharing options...
bmwking Posted October 7, 2018 Report Share Posted October 7, 2018 im surprised the wire wheel on an angle grinder didnt do the trick tho. Link to comment Share on other sites More sharing options...
BassMunky Posted October 7, 2018 Author Report Share Posted October 7, 2018 Well it a cordless makita. Could be battery dead. Doubt it. Try tomorrow. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted October 7, 2018 Author Report Share Posted October 7, 2018 Anyone had this problem? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
Bret Posted October 7, 2018 Report Share Posted October 7, 2018 Wire wheels are only good for putting out an eye. BMWKing's idea of a flapper wheel on an angle grinder is a good idea or a psa sander, but most people don't have one. If you don't have those things you could try putting on some acetone and use a paint scraper or a paint scraper without acetone. Link to comment Share on other sites More sharing options...
BassMunky Posted October 7, 2018 Author Report Share Posted October 7, 2018 47 minutes ago, Bret said: Wire wheels are only good for putting out an eye. BMWKing's idea of a flapper wheel on an angle grinder is a good idea or a psa sander, but most people don't have one. If you don't have those things you could try putting on some acetone and use a paint scraper or a paint scraper without acetone. Ook may try that. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
bmwking Posted October 7, 2018 Report Share Posted October 7, 2018 3 hours ago, BassMunky said: Well it a cordless makita. Could be battery dead. Doubt it. Try tomorrow. if it's a lithium battery, it wont throttle down, it'll just stop. no loss of power, just a full stop. but go grab a 120 grit flapper disk that fits your collar from harbor freight for a couple bucks and come back at it. reconing isnt a job you should rush or do something to "make it work" do it right the first time, no matter how much time it takes, and you wont have to do it over. Link to comment Share on other sites More sharing options...
BassMunky Posted October 7, 2018 Author Report Share Posted October 7, 2018 2 hours ago, Bret said: Wire wheels are only good for putting out an eye. BMWKing's idea of a flapper wheel on an angle grinder is a good idea or a psa sander, but most people don't have one. If you don't have those things you could try putting on some acetone and use a paint scraper or a paint scraper without acetone. Ook may try that. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
audiofanaticz Posted October 7, 2018 Report Share Posted October 7, 2018 I got a 50 grit flap disc in a right angle grinder that I use for cleaning baskets... ever cleaned a basket without one.. I seen some peoples method in prepping a basket and having shit left all over it... yea nope not unless you want your recone to fail from a shit bond or rubbing due to installing it on a uneven basket. Take that wire wheel and throw it in the trash... Its just going to be a headache for cleaning a basket especially when the wires break off and get stuck over the magnet and possibly in a gap through a vent (assuming you got the gap taped off on top of coarse). Link to comment Share on other sites More sharing options...
