Opinions on two designs thanks
jessdabest77
I'm deciding between two different  set ups and would like your guys opinion. I have a 2200 watt amp does 1 ohm with good electrical. The subs I'm deciding between are four Sundown E8 v.5's or a single Sundown U12.  Which would sound louder and lower between both? I have room for either but would like to hear your opinions. Wish I had funds to try both but unfortunately can only do one.
If those are the only two choices you will consider, I'd lean towards the four E8s.  This is assuming both would be in a 2.0 cu ft net box tuned to 32 Hz.   If you have more space than that to work with, it may change things.
Builds:
The 4 E8s should outperform the single E12 in their respective recommended enclosure sizes so 3 net for the E8s, 2 net for the U12 on the same power:
* orange plot is for the 4 E8s, red for the single U12.
One thing to bear in mind is which option you could overpower the most and what's your maximum box size
  • 1 month later...
  • Who's Online   0 Members, 0 Anonymous, 976 Guests (See full list)
