Krazykid122 Posted January 6, 2019 Report Posted January 6, 2019 (edited) So i tuned my system with the DD1 and CC1, and my amplifiers bass knob clip led still lights up a good bit saying im clipping whenever i turn the system up to normal listening volume (36/40) and turn the bass knob halfway up or more , if any less it just doesn't really beat that hard. I know the led on the knob is not very accurate, but when tuning with the DD1, the distortion led would light up before the bass knobs clipping led, so i know if the bass knob is lit then it has to be distorting, or im assuming at least. I was told that since my music source is from my iPhone Via USB and the test tracks were on CD that could be it, so i loaded all the tracks to my phone and tuned everything with the audio source being my phone through USB, no difference. I cant figure out why im still clipping and making the woofer smelly with proper electrical and tuning with the DD1, its like there is no distortion while tuning but as soon as i hook the woofer up and play it does, Ive got to be doing something wrong. If i left out any info needed ill add whatever is needed, thank you! Equipment is in signature Edited January 6, 2019 by Krazykid122 Quote 02 Dodge Durango 1 Fi SP4 18" .v2 Sundown SCV3k @.5 Ohms XS D3100 up front Northstar SMS AGM 400 in the back All XS Power 0ga OFC 240a Apex h/o alternator Pioneer AVH-X2500BT HU Dual 0ga runs from the alt to battery Dual 0ga runs from battery to amp
will77530 Posted January 6, 2019 Report Posted January 6, 2019 Well what track did you use to set everything with the dd-1 Quote
CstrokerV Posted January 6, 2019 Report Posted January 6, 2019 his electrical isn't up to par with running at .5 ohms in my opinion ...... what was your setting at where was the knob at when setting with the dd-1 Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
Krazykid122 Posted January 6, 2019 Author Report Posted January 6, 2019 34 minutes ago, will77530 said: Well what track did you use to set everything with the dd-1 track 5 for the compromise of loud and SQ Quote 02 Dodge Durango 1 Fi SP4 18" .v2 Sundown SCV3k @.5 Ohms XS D3100 up front Northstar SMS AGM 400 in the back All XS Power 0ga OFC 240a Apex h/o alternator Pioneer AVH-X2500BT HU Dual 0ga runs from the alt to battery Dual 0ga runs from battery to amp
will77530 Posted January 6, 2019 Report Posted January 6, 2019 Where was your bass knob set when you did this turned all the way up? and your treble and bass in the deck where were those set and did you change them after? Quote
Krazykid122 Posted January 6, 2019 Author Report Posted January 6, 2019 (edited) 15 minutes ago, CstrokerV said: his electrical isn't up to par with running at .5 ohms in my opinion ...... what was your setting at where was the knob at when setting with the dd-1 bass knob was all the way up, The alternator company and The Amp Lab where i got it said my electrical is okay for the 3k @.5 and the voltage is pretty stable, im going to go back out and check over everything really good with a DMM. Edited January 6, 2019 by Krazykid122 Quote 02 Dodge Durango 1 Fi SP4 18" .v2 Sundown SCV3k @.5 Ohms XS D3100 up front Northstar SMS AGM 400 in the back All XS Power 0ga OFC 240a Apex h/o alternator Pioneer AVH-X2500BT HU Dual 0ga runs from the alt to battery Dual 0ga runs from battery to amp
Krazykid122 Posted January 6, 2019 Author Report Posted January 6, 2019 1 minute ago, will77530 said: Where was your bass knob set when you did this turned all the way up? and your treble and bass in the deck where were those set and did you change them after? everything was flat for tuning bass knob all the way up Quote 02 Dodge Durango 1 Fi SP4 18" .v2 Sundown SCV3k @.5 Ohms XS D3100 up front Northstar SMS AGM 400 in the back All XS Power 0ga OFC 240a Apex h/o alternator Pioneer AVH-X2500BT HU Dual 0ga runs from the alt to battery Dual 0ga runs from battery to amp
will77530 Posted January 6, 2019 Report Posted January 6, 2019 You say it was flat for tuning did you turn things up after tuning Quote
Krazykid122 Posted January 6, 2019 Author Report Posted January 6, 2019 1 minute ago, will77530 said: You say it was flat for tuning did you turn things up after tuning No down, 40hz and 80hz on the hu eq all the way down, I actually tried tuning the amp with the eq like that first just to see the difference from flat and all the way down and I could turn the hu all the way to 40/40 with no distortion unlike a when flat, but I still use 36 as max volume. Quote 02 Dodge Durango 1 Fi SP4 18" .v2 Sundown SCV3k @.5 Ohms XS D3100 up front Northstar SMS AGM 400 in the back All XS Power 0ga OFC 240a Apex h/o alternator Pioneer AVH-X2500BT HU Dual 0ga runs from the alt to battery Dual 0ga runs from battery to amp
will77530 Posted January 6, 2019 Report Posted January 6, 2019 Go buy a good ol fashion cd not a mixtape you and your boys made but a good ol fashion cd pop that bad boy in there and see if you have the same problem if not then your media source sucks all the balls Quote
