Box electric posts
I have bolts that pass current thru the box and have come to notice that the negative bolt is getting hotwhile the positive isnt. Also have the subs wired out of phase. My question is should the bolts get hot?
Plus i noticed that i didnt tighten the bolts enough in the beginning and about started a fire.  Click for pics
the under tightening is likely your problem.  a loose connection can cause electricity to arc or jump gaps.  tighten all your connections down and see if the problem continues.
  • 3 weeks later...
Is it bad to just run wire out the port?  Or drill holes size of wire and fit them through and Seal with glue?  Or are terminals a must?
♦ Sundown NSV4 18"  +  Sundown SALT-4 Baby
♦ MechMan Elite 370a  +  XS3100 - XP3000
♦ SHCA 1/0 OFC(blue)  +  SMD Fuse Holders(blue)
♦ Pioneer AVH-2440NEX  +  SHCA Pro RCA
So i go to test the head unit again.
Vol 30 rca volt is about v2+.
Vol 35 volts about v2.5+
Vol 37 to 40 it jumps to about v3 - v4
While oscope shows signal clips about 39
Is the head unit rca output takeing a crap?
Rvc are from an belva amp kit i had.
  • Who's Online   0 Members, 0 Anonymous, 4882 Guests (See full list)
