Silverado factory integration
Please refresh my memory, What head Unit will you be running ??? If I remember correctly, you will not need factory integration for the DSP, but for the primary source unit.
Hmmm, You may need to find someone to give you a OEM wiring diagram to help determine what you can wire up to the DSP. Does the Mosconi say it works as a factory integration unit ???
I would think nothing would change sticking with OEM, just take the inputs to the factory amp(s) and direct them to the DSP ...
Which Mosconi DSP you got Sir ???
