Uncleshizz Posted January 23, 2019 Report Posted January 23, 2019 Ok so I'm new here and just want to apologize before hand if I pose a question in the forum. I have an old school Orion HCCA 12 that I would like to rebuild/have rebuilt, but can't seem to find any information on a recone kit. I only know that the sub came out in like 1998-99. Is there any company that makes a kit or rebuilds them? Any info would be greatly appreciated. Thanx
ehall8702 Posted January 29, 2019 Report Posted January 29, 2019 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F264025634389 Lots of em on ebay, whats exact model of ur sub and ill dig around and find ya one if u want. I have a few drinks nd get zoned out on ebay anyways might as well help someone out in the process lol 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
Bret Posted January 30, 2019 Report Posted January 30, 2019 I just did an old m&m godfather that sat in my friends back yard 20 years. The voice coil had a hornets nest in it. I took it apart and measured everything and bought comparable/generic parts. I did reuse the voice coil which was a real pain in the ass, but can be done. Now I'm doing a g&s redline. Same story, but I managed to not destroy the cone this time so I might reuse it if I can get the spider off it. If the dust cap is paper or felt you can put a little acetone around the edge and carefully remove it. It is a lot easier if you can get a complete recone kit, that's for sure.
