So my 2014 Ford fusion is a great for tight spaces. And having trouble coming up with a alternator bracket design. But dream system simply can't happen without it. I atleast need some ideas for a bracket, mounting points and such unless someone may be willing to make me one. I've figured out (and I hope correctly) the max I can put in this thing is about 6k-7.5k of bass on 4 or 5 u series 10" sundown subs, and 800 watts of crescendo mezzo components on an c1100.4. If 6k then crescendo 6k amp, if 7.5k then sundown amp. I'mguessing  3 or 4 270 amp alts plus stock 170 amp alt, 3 or 4 xp3000's for secondary, 1 d3400 to replace starter battery, all alts 2 runs 2/0, (how should I connect wires in this system?, there are many options. All power to starter bat then starter bat [same amount of total runs to rear secondaries 2/0] to first secondary and so on or starter bat to each secondary battery [one run to first, one run to second and so on] then secondaries to amps using 1/0 and dual inputs to amps. Then for grounds, from alts, ground to chassis or run ground to chassis and starter bat then to secondaries, or all battery and alts ground to chassis? That's for audio, then I'm estimating on the high end 1000 watts for lighting system. Also do I have enough batts and alts in the system planned? Am I short or to much? Should I add lithium if so how do I wire that into the system?
This is a link to engine bay pics for reference.
https://photos.app.goo.gl/1PvssHTzAfz4qmW78
I don’t think you will be able to use Astroglide to push in that many alternators in that particular vehicle. Good luck.
Your on a roll today? lol
Hell of a build plan you got there. Tight under the hood! good luck and start a build log so we can follow your progress.
Well, I'll need to mod the hood afterwards for it all to fit but the extra alts will have to set on top of the engine mounted to a custom bracket. Lol I do like your astroglide comment though lol.
  • Who's Online   0 Members, 0 Anonymous, 4882 Guests (See full list)
