Priuslows Posted April 4, 2019 Report Posted April 4, 2019 When setting gains on strapped amps do in use the terminals from the master or leads going to the subwoofer Ex. Positive from slave is (-) and positive from master is (+). Quote
DiBo Posted April 4, 2019 Report Posted April 4, 2019 If it we're me I'd set the gain on one amp without it being strapped then I'd strap the amps together and not mess with anything. The slave amp automatically falls in line with the master. I've heard that a weaker slave amp is bad because the master can cause the slave to clip. Seems a little extreme to me but it makes sense. It'd be nice if all amps came with a birth sheet haha. Just food for thought. Quote
BassMunky Posted April 4, 2019 Report Posted April 4, 2019 Both see any difference Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Priuslows Posted April 4, 2019 Author Report Posted April 4, 2019 5 hours ago, DiBo said: If it we're me I'd set the gain on one amp without it being strapped then I'd strap the amps together and not mess with anything. The slave amp automatically falls in line with the master. I've heard that a weaker slave amp is bad because the master can cause the slave to clip. Seems a little extreme to me but it makes sense. It'd be nice if all amps came with a birth sheet haha. Just food for thought. This is what I did. I was just looking for some reassurance. And any other knowledge on the subject. Thanks Quote
CstrokerV Posted April 4, 2019 Report Posted April 4, 2019 If you do the measuring one and then strapping you need to do both amps to see what one distorts first and put that one as master Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
Priuslows Posted April 5, 2019 Author Report Posted April 5, 2019 12 hours ago, CstrokerV said: If you do the measuring one and then strapping you need to do both amps to see what one distorts first and put that one as master Is there another way to set them? Quote
