Crown Vic Budget Build 2x Sundown LCS
26 minutes ago, Ron36 said:
Gonna need a bigger amp now those subs can handle 1k each allday.
Yup. Thats my plan. Another Soundqubed s1-1250. Going to try strapped and gain matched. Going to pick up a 200amp alternator also off the P71/cop car vic. Going to compete for the first time next month!
Received my 2nd Soundqubed S1-1250. I have them strapped right now, but may try gain Matching? Going to Droppin Hz Next week to get my gains set, so ill be good for Sundown Audio 2019. I really didn't want to rebuild my amp rack right now so i modified it to fit both Soundqubed S1-1250's. Still need to mount my 4-channel amp. I picked up a 4-way Fused Block today  - 1/0 in and 4-4ga out. Do you think i will be fine running all 3 amps on that? or to much current draw for 1/0?
Here is pics of my modified rack
Put a fuse block in today and cleaned all the wiring up. Now I need to second skin my back wall/seat
Mirror feel off today
Adding to my system slowly. Added sound deadener to the rear. This sound deadener is a lot better than the Amazon Kilamat. Fixed all the chipped trim on the side of my car. Also made a bass knob to match my car with left over paint
I will post finished pictures tomorrow. It got dark
Put Tesa tape on all the wires. Finished up the back wall. Next is to clean up the wires in the back and carpet the  back side of the battery/amp rack. Then techflex all the wires and sleeve the big 3 under the hood.
  • 1 month later...
Its been a while since i updated this build log. The build has come a long way. Always upgrading now lol. I have added a Twisted Sounds 3.5k @.5 ohm, 4 Banks of XS Power Super Caps.
I won NSPL World Finals in my Class - Trunk Eliminator 0-24 which is awesome because it was only my 4th show. Only had a couple people that helped @shredder2 and a good old DMM.
I will post a picture of the banks soon
Awesome
I only did one class Trunk Eliminator 0-24. 145.1 in the kick. Which is lower than my last show, but the heat in SC Sunday killed me. Going to be buying a Brand X alternator in the next 2 weeks.
Edit. That's on a 30 second music run
I'd redo the enclosure for your power, 55in2 ain't enough port for a TS 3.5 at .5 for sure. Great #'s considering your setup (trunk, low port area and tuning).
Btw... I'm curious... what seems to be your peak frequency in that Vic?
