Could you provide info on how you're wired, how gains are set, and what you've checked so far?
Your box could have loading issues , one of the pairs are wired incorrectly or it could be an amp gain problem
Walled Police Interceptor
Four 15s
160s
I got 2 Rockford fosgate 1200.1d the 4 12s are dual 4ohm sub both set are wired down to 1 ohm and how the box made the port is on the side at the bottom
RCAs can go bad are you running the RCA pass thru one amp into the other or splitting before. Process of elimination maybe try one amp at a time then switch which pairs of speakers are connected to what amp.Will determine if its a RCA signal issue, amp issue or wiring.
Four 15s
160s
