DaveG Posted May 20, 2019 Report Posted May 20, 2019 Hi everyone was wondering if I can run a second 0 gauge wire from alternator to second and third battery in the trunk which are in parallel. Does that make any sense or is it a dumb idea? Please help.
BassMunky Posted May 20, 2019 Report Posted May 20, 2019 Yesss Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
DaveG Posted May 20, 2019 Author Report Posted May 20, 2019 Was that confiming its safe or was it not a good idea? Can you explain? Thanks
SnowDrifter Posted May 20, 2019 Report Posted May 20, 2019 The alt is the ultimate source of power for your equipment. The shorter runs / fewer connections you can make in the process, the less your voltage loss due to resistance. It's important to consider where your fuses are when wiring in this manner. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
DaveG Posted May 20, 2019 Author Report Posted May 20, 2019 7 hours ago, BassMunky said: Yesss Thanks for reply SnowDrift yet im still a little confused bc you saying fewer connections the better but shouldn't extra wire create less resistance so it's not cramped up in one wire that's gonna be pushed to its limits at around 3300 watts? 6 hours ago, SnowDrifter said: The alt is the ultimate source of power for your equipment. The shorter runs / fewer connections you can make in the process, the less your voltage loss due to resistance. It's important to consider where your fuses are when wiring in this manner.
SnowDrifter Posted May 20, 2019 Report Posted May 20, 2019 Current flow wiring to front battery: Alt -> Fuse -> Battery -> Fuse -> Fuse -> Rear Battery -> Fuse -> Amp -> Ground Path Current flow wiring to alt Alt -> Fuse -> Rear Battery -> Fuse -> Amp -> Ground Path Note: Your connection between alt and front battery should be fused and would cover the wire coming off the alt going to the rear. The alternator is not a fusible item as current stops when it stops turning. It's not included in this current path because as this is written with the premise that the alt is the ultimate power source for your system ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
White Lightning Posted May 20, 2019 Report Posted May 20, 2019 According to old school competition rules, you must have a fuse within 18” from a battery. Wire from the fuse to the battery must be no longer than the length of the battery. Do not over fuse. Run smallest fuse possible to let system operate. The ideal place under the hood IS the Alternator for running wire to rear mounted batteries. hope this helps. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
BassMunky Posted May 20, 2019 Report Posted May 20, 2019 I thought biggest fuse. I run all 300 amp fuses. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Guest Posted May 20, 2019 Report Posted May 20, 2019 wire all of your positive wire runs from your battery under the hood. fuck going straight from the alternator unless u are a into termlab.
