07 yukon xl, combining the trucks electrical system with audio side..
I Have been running my truck and lighting on the stock alternator and electrical system. I have 3 370 amp CES alternators running the audio side of the truck.  07 yukon xl 5.3
I have ordered a 270 amp CES alternator to go into the stock location and I want to combine the truck and audio side so they are not seperate anymore.
Has anyone done something similar and did you run into any issues? The stock alternator is controlled by the pcm and it shows 15.2 volts on the stock volt gauge in dash, at times it shows around 13.5 or so.
From what I have gathered in my searches The only issue i will have is bypassing the pcm and from what I see it only causes a battery light in the dash.
The final destination here is to run all 4 alternators on a adjustable external regulator that is setup to control all 4 alternators and have the ability to shut off each alternator individually...
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
Keep them separate. Also 15.2 is high.  Do you have your truck side ground ran through the battery current sensor?   If you have a ground on any battery for the stock side it needs to be ran through the sensor or it will cause a high charge like you have now
  • 9 months later...
@MasterbasserNice setup!
I am over here just trying to figure out how to keep my single Mechman 320 alt charging above 13.8! You have three alts to deal with yikes!
2006 Nissan Titan Crew Cab
XS Power D6500 up front, Mechman 270 amp alt,
Front Stage:Hybrid Audio Legatia Tweeters and Midrange drivers in Custom A Pillars, HA Unity 6x9 inch Midbass in the doors, powered by an Arc Audio 1200.6 X2 and connected to a JL TWK 88 DSP
Subwoofers: Four 8 inch Soundqubed Subs in a ported enclosure. Incriminator Audio 20.1 on the subs (@ 1ohm)
Performance: JBA Headers, Uprev Tuned, Dynomax bullet muffler, 3 inch exhaust all the way back. Air raid CAI.
Wheels: 18 inch Balistic Jester wheels on 33 inch Nitto TG2's
Suspension: 6 inches of lift total. DK UCA's, DK LCA's, Icon coilovers up front, Bilstein Shocks in the rear with 4 inch blocks
2007 Chevy Suburban LTZ
Engine: 5.3 DOD Delete, BTR Stage 4 truck Cam, TSP Headers, Gibson Catback exhaust. Tuned by Sam @ Advanced Modern Performance.
Suspension: 2/4 Belkin drop. Belkin Sway bars, Spohn Panhard bar
Audio: Pioneer 8400 NEX Head unit, Audio Dynamics DSP, 6th order enclosure with three 10 inch DC Audio Level 4s behind the third row. Wolfram 4500 on Subs, Wolfram AW 250.4 on the front stage Dual SkyHigh Car Audio 8 inch mid bass in the doors, quad 3.5 inch midrange drivers in the A-Pillars
Dual Alternators, Mechman 320 powering a CES 40ah Lithium battery, OEM alt has an AGM on it.Viper remote start.
Wheels:  24 inch Luxx wheels/ 305/40 R24
Grammatically speaking, Prolly is not a word.
15 hours ago, ToNasty said:
Turn the headlights on
Didn't do anything...my voltage went to from 13.8 to low 13s.
My Suburban is PCM controlled already. I have 0 gauge going through the sensor as we speak. I might have to start troubleshooting and see where the actual problem is. Ive read that certain conditions "activate" or allow for higher charging such as turning on headlights, driving in tow mode and a few other things.
Why don't you just bypass the PCM altogether?
Yeah, I figure thats the best way to go...dual alts for my setup. 15.3 to the lithium for Audio only. AGM for the stock alt.
  • Who's Online   0 Members, 0 Anonymous, 4175 Guests (See full list)
