New components needed!
ehall8702
Yeah the components are 3 ohm, and absolutely no room to add 6 1/2s to the rear c pillars, not without custom pods or something like that and I am not willing to modify ANY panels on my truck. As far as distortion on the rears, I will have fader very far to the front just letting the rears have some fill, probably won't even make a difference so may not even hook them up. Luckily my pioneer maxes at 37 and signal distorts at 35. Chances r won't be any distortion on the rears but again doubt they will be loud enough to even bother hooking them up honestly. I have checked and tuned everything with my trusty ol oscope, ZERO distortion ( well at least to 35 lol). I think I will get a matching amp to what I have ( smaller series) and run two sets of the references ( set in doors and a set in kick pods) active. I want a dsp anyways but have an electronic x-over that'll suffice till I get a dsp.
That's signal distortion.
Completely different than the built in amps distortion.
Signal has nothing but a few volts, and it's line level.
Amplified power is lots of volts and is amplified.
I’m assuming you’re doing this to a GMT400 truck by your signature.
I know from personal experience that there’s a lot of work you can do to the doors to optimize driver performance. Just Saying
Obs Chevy extended cab pickup. Have fast rings, and foam buckets on the door speakers already, have tweeters In factory locations. What else would be a good way to get more sound out of what I already have?
Sound deadner, mass loaded vinal, steel bracing, etc ...
Have been saving for sound deadener , bracin is probably more than I'd get into...will check into "mass loaded vinal", have no idea what that is lol
Was checking out mass loaded vinyl, basically same as sound deadining without adhesive right? I'm not gonna go too far right now since I am trying to get my hands on some new doors, these have some rust on them and it's more than is easily fixed with a new door skin. I may just spray inside if the door with ruberized undercoating till I get my new doors and can do those right.
32 minutes ago, Gunnem said:
im not sure if u said u cant do 6.5" anymore but...
I personally love the soundqubed pro audio 6.5", pair for $42.
the magnet is huge though so if its going in your door make sure u have enough room
https://soundqubed.com/product/qp-mr6-5-pro-audio-midrange/
Can do 6.5s in front doors, plenty of room there, said I can't do 6.5 in the rear c pillars, factory is 4x6, so I used adapters and used 4" infinity references , prolly gonna scrap even using them, and they will stay there cause it's a MOFO to remove or replace them ya know?
I’m not much on MLV either, but sound deadner is a must ...
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
