Rear speakers not playing HELP!
Dragonware
Eminence 8 (front)8ohm+ eminence 6.5 (rear) 8ohm wired in parallel to a 2ch amp 750rms at 4ohms . Worked in 2 vehicles fine for 7 years. Suddenly both rear speakers are not playing any ideas before I RIP apart my doors.  The wires at the amp are not loose.
And each speaker has it's own dedicated wire run from door directly to the amp.
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
U try a diff speaker at the amp to eliminate the amp as the issue? Rca issue maybe? Headunit issue? If there is a short in the speaker or speaker run most amps would protect.
10 hours ago, MrSkippyJ said:
Is it wired for a front and rear speaker on each channel or rears on one channel and front on the other?
2 ch amp  both wired for front left and right . The front doors still play left and right balance is fine but the back doors just stoped playing . Blown speakers u think ?
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
Amp is stil playing the front doors which are parallel to the rears. Only one set of rca in . Head unit is running into a line output converter
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
2 hours ago, CrackFactory said:
I bet they are blown if the front are still playing and you have them in parallel with the rear.
7 years tho same configuration same power 2 dif vehicles and just like that poof ??
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
yessir, thats how it works with mids when u get power to em. prolly could take off center cap and resolder the leads to the voice coil and theyd work again, but prolly wouldnt last too long . ive noticed the leads fatigue and break right there.
  • Who's Online   0 Members, 0 Anonymous, 735 Guests (See full list)
