Kylemoney01 Posted July 18, 2019 Report Posted July 18, 2019 i Have a Pioneer GM-9701 getting power but getting nothing out of the speaker outputs. Did continuity on everything and everything seems good tried switching things around and nothing. Do I have a bad amp or am I missing something.
Kylemoney01 Posted July 18, 2019 Author Report Posted July 18, 2019 16 minutes ago, Ripkon said: You using RCA from the Head Unit? They go to a line out converter
slowfkncar Posted July 18, 2019 Report Posted July 18, 2019 Try a different amp or try plugging in a different source(mp3 player,phone ect) to test the rca inputs or use a DMM, play some music and check your line out converter for ac voltage at the amp side.
Kylemoney01 Posted July 18, 2019 Author Report Posted July 18, 2019 48 minutes ago, slowfkncar said: Try a different amp or try plugging in a different source(mp3 player,phone ect) to test the rca inputs or use a DMM, play some music and check your line out converter for ac voltage at the amp side. I tried radio phone and cd still nothing. I just checked voltage at the remote wire at the amp and has 12 volts. Should there be voltage at the rcas? Also teste continuity on the rcas they were good.
Ripkon Posted July 18, 2019 Report Posted July 18, 2019 Try a aux cable to rca or anything with rca with sound directly to the amp
BassMunky Posted July 18, 2019 Report Posted July 18, 2019 Maybe, test everything Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Roadmaster-Build Posted July 18, 2019 Report Posted July 18, 2019 I agree with bassmunky check everything. Should have some sort of output from the rcas, check the level adjustment on the loc too. Pretty much falls in the lines of checking everything.
