So our explorer does not start correctly, theres this horrible sound when we try to start it anytime its set for even 10 minutes. After i have it started i can immediately turn it off and back on and it will start fine.
I was thinking that it was a starter problem because previously i sprayed it with WD-40 and the problem stopped temporarily. I took this vid of it for help purposes, and was hoping someone could tell me if im on the right path as well as a place i could take it to get fixed and what kinda price im looking at.
thanks in advance
James
P.S. i know i started a starter post before but i figured id post a new post since i took a video
thats weird... but hey look at it this way. atleast you got more gas in yours then mine.....lol.
have you tried any explorer forums?? might get better results, even tho im sure theres some mechanics on here.
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
your problem can be a few things,
that sounded just like you have some missing teeth on the flywheel or missing teeth on the starter. or you may need to have the starter spaced back a shim or two...
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
any ideas on cost?
and i hope for your sake its just a starter, if its the flywheel , the tranmission will have to be removed and a new flywheel put on and a new starter which will cost atleast 700 dollars for a shop to do the repair with parts
yea my flywheel raped my starter gear and now they are both fucked :unsure: but a new flywheel cost me about $30 and a starter drive was $15. I have the local votec school that i go to doing the work for free B)
DC.jpgDC POWER
well thats the bad thing about paying someone to work on your car, they dont think or care enough to check out other items in a area hard to get to when there at that location, or you might get lucky and the person check out parts that need to be fixed replaced while in that spot to save money even tho it will raise the bill of the repair...
like i said i hope its just a few missing teeth on the starter and not the flywheel thats a pain in the ass
