So I am having some trouble with some noise in my system. Currently, I am running a TWK-88 DSP to a Rockford Fosgate 4 Channel Amp to run my 2 way active system. I always get a low hissing noise and alternator whine through the speakers. I have tried unplugging the 2 sets of RCAs that go to the amp from the DSP and that makes the hissing and whine go away. So I know it's not the amp introducing noise. Another extremely weird thing I have run across is if I have only 2 of the 4 RCAs run to the amp, then I get a very loud hissing noise. I have also tried plugging the RCAs directly into the amp, and I still get noise into the speakers. So I am guessing the noise is coming from the RCAs. I am using Stinger 4000 series 6 channel RCAs. They are running opposite side of the car as the power wire, but next to two sets of speaker wires.
I am having trouble tracking down what part of the system is bringing the issue.
Any suggestions?
Could it be the head unit, or the RCAs, or a grounding issue, or...?
Okay. What should I look for? Currently, my amp is grounded to a seat bolt with the paint ground down. I get a 0.01 ohm reading between there and the battery ground. The DSP is run off the same power and ground as the head unit. Should I check that ground?
yes check that ground too but I would guess your speaker wires for your active setup are cheap or pinched or touching something it shouldnt
I have really good speaker wires. 14 Gauge OFC from Sky High.
I've checked everything behind the dash. I've grounded the headunit to the chassis. I don't know what else to try. I am still getting the alternator whine through the speakers. Could the RCAs be picking up noise? Would it be worth trying a different set?
At this point, I am tempted to just run a ground wire from the battery to my distro block.
When I unplug the RCAs from the amp, nothing comes out of the speakers. Complete silence. Should I look at the RCAs then?
