6th order or aero port box?
escottl92
11 minutes ago, CstrokerV said:
Well the 6th order is probably going to be to big unless you do a blow through .... and any properly built box would work
Agreed. I had a design for a single 18 6th order a few years back. It wouldn't fit in a silverado extended cab with seats moved forward
5 minutes ago, escottl92 said:
Thank you for info
sounds like I should try aero port box
What are the specs of your current slot ported box?  There is nothing aero ports can do that slot ports can't, so there is absolutely no guarantee that going to an aero port box is going to do a damn thing for you.  It may just be that you have a poorly designed box.
Builds:
Around 13cuft internal
54.5”L x 25”H x 28”W
L port 25” long —7.75”W x 21” x 25” long
tuned 32
only hitting 153db
2 ampere audio 7500.1 amps
320alt
AGM under hood
xs 7500d batt in back plus full throttle 1100
big 3 done, lots of 1/0 wire
sound deadened roof, doors, floor, back wall
tuned 32
only hitting 153db
320alt
AGM under hood
  • Who's Online   1 Member, 0 Anonymous, 1565 Guests (See full list)
