Engine noise
I'm getting some engine noise from my speakers while my vehicle is running. I have  double checked all the ground to ensure they are solid. I've read through a few topics on here saying it could be my RCA however I unplug my RCAs from the h/u and I'm still getting the noise. I've even added an extra ground from the Headunit and bypass since I know  some pioneer unit have this problem. ( mine is an AVH-X5800BHS)  I don't believe it s the alt because  it doesn't get louder or change  at higher RPM.  Fuses are all good as well. If I turn the source off on the h/u it stops. Would another ground from the H/u itself to the Chassis help? Any suggestions would be appreciated.   I've attached a sound clip if it help.
My recording 1.wav
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
How does one measure resistance of a ground? I was under assumption that a Meg meter was needed?
Do you take neg battery post on one lead and then other lead to your frame or chassis ground?
It is a Jeep so that might be a thing I need to do
  • Who's Online   0 Members, 0 Anonymous, 4882 Guests (See full list)
