BassMunky Posted January 15, 2020 Report Posted January 15, 2020 Jvc 840 deck Mid high 4 channel sundown Front channel high Rear mids What setting I put on deck I running active Front rainbow tweeter germanium Rear rainbow mids Now on deck I put both on pass through Or 80hz? Front tweeter channel 1 and 2 Rear mids 3 and 4 Setting on amp is set for the mid and high? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 15, 2020 Author Report Posted January 15, 2020 What freq for each on the deck? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
MrSkippyJ Posted January 15, 2020 Report Posted January 15, 2020 maybe active isn't for you. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
BassMunky Posted January 16, 2020 Author Report Posted January 16, 2020 Wahhh , noo cause I had my trick fixed and they disconnected the battery and reset everything Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
slowfkncar Posted January 16, 2020 Report Posted January 16, 2020 You should have wrote it all down lol. If they are germanium w165's & cal 25's I'd probably try something like 2.5khz/3khz @ 12db for the mid, 3khz-3.5khz/24db for the tweets. If tweets are mounted far from the midbass, you might prefer reversed phase on the tweets or mid.
BassMunky Posted January 16, 2020 Author Report Posted January 16, 2020 4 minutes ago, slowfkncar said: You should have wrote it all down lol. If they are germanium w165's & cal 25's I'd probably try something like 2.5khz/3khz @ 12db for the mid, 3khz-3.5khz/24db for the tweets. If tweets are mounted far from the midbass, you might prefer reversed phase on the tweets or mid. That already setup on the sundown 100.4 my question what in the jvc deck there no 12db or 24 db on deck setting Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 17, 2020 Author Report Posted January 17, 2020 bumpp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 17, 2020 Author Report Posted January 17, 2020 Uppp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 17, 2020 Author Report Posted January 17, 2020 FreshFresh Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
MrSkippyJ Posted January 18, 2020 Report Posted January 18, 2020 How did you figure it out the first time? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
