BassMunky Posted January 22, 2020 Report Share Posted January 22, 2020 So today 2 of the 3 fuses blew on my sundown 100.4 sax amp. What could have caused it? Everything is set properly and only running a set of mid and high.. I have been running it for 6 yrs no problems Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
abdc Posted January 22, 2020 Report Share Posted January 22, 2020 Double check your ground. If it is loose or wobbling it can cause random spikes and feedback to the amp. 1 Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted January 22, 2020 Report Share Posted January 22, 2020 Speaker wire shorting out anywhere? What about power wire? Frayed ends coming out? 1 Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Ron36 Posted January 22, 2020 Report Share Posted January 22, 2020 Corrosion over time , check and clean all connections. 1 Quote 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
BassMunky Posted January 22, 2020 Author Report Share Posted January 22, 2020 Soo my dumbass took the 3rd fuse out. Pit it back in and started the truck. I had no fuse for 1 and 2.... what happened was sou ded line engine whine for 20 sec then the 3rd fuse blew.. I should have left it out? I'll try check my wiring today and the grounds... thanks I'll get new fuses too Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted January 23, 2020 Author Report Share Posted January 23, 2020 Bumpp Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted January 23, 2020 Author Report Share Posted January 23, 2020 14 hours ago, Ron36 said: Corrosion over time , check and clean all connections. Will do anything else? Could the engine noise be caused from only 1 fuse? Also my speaker wires cross the power is it ok? Not touching maybe 3 in away Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted January 23, 2020 Author Report Share Posted January 23, 2020 18 hours ago, SnowDrifter said: Speaker wire shorting out anywhere? What about power wire? Frayed ends coming out? I'll try redo all the wires and sand the ground will it help? Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted January 23, 2020 Author Report Share Posted January 23, 2020 20 hours ago, abdc said: Double check your ground. If it is loose or wobbling it can cause random spikes and feedback to the amp. Ok will do and report back Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
SnowDrifter Posted January 23, 2020 Report Share Posted January 23, 2020 3 hours ago, BassMunky said: I'll try redo all the wires and sand the ground will it help? If it will help is dependent on if that's the problem. Give the drivers it's powering an inspection too. Make sure a tinsel didn't pop off or cross somewhere 1 Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
