AI James Posted May 10, 2008 Report Posted May 10, 2008 can you throw some specs up at 2ohms and 1ohm please just for reference sake. and i mean manufacture specs not what it will do.
Aaron813 Posted May 10, 2008 Report Posted May 10, 2008 Logan are you talking about metal corner bead or plastic is its plastic its useless for you if its metal thats another story
loganberry Posted May 10, 2008 Author Report Posted May 10, 2008 Channel: 1 (MONO) Minimal Output Impedance: 2 Ohms RMS Potency @ 13,8V / <0,5% THD Mono 1 Ohm: Mono 2 Ohms: 2.000 Watts RMS Mono 4 Ohms: 1.250 Watts RMS Impedância de entrada: 20 K Ohms Input Sensitivity: 0,3 a 10V Total Harmonic Distortion: < 0,5 % THD Signal to Noise: > 90 dB Crossover Frequency LOW PASS: 50Hz a 15KHz Frequency Response (FULL RANGE): 20 Hz a 15 KHz (-3dB) Input Tension: 9 a 16 V Drain with music: 1,5 a 100 A Drain with Bass or Competition: 1,5 a 200 A Dimensions (Alt. X Larg. X Comp.): 65 x 280 x 300 mm Weight: 4,0 Kg metal, and its sitting in my garage now My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Aaron813 Posted May 10, 2008 Report Posted May 10, 2008 Ok thall work out god for the indies to seal the corners really good. Good idea Logan i might try that out on a box im building soon
ALPINE408 Posted May 10, 2008 Report Posted May 10, 2008 2000 rms at 2. Ohm or 1 ohm depends if you get 1 ohm or the 2 ohm model at 12.4 volts 1200 rms at 4 ohm Have you ever had your woofers blown?
ALPINE408 Posted May 10, 2008 Report Posted May 10, 2008 Oops to slow Have you ever had your woofers blown?
loganberry Posted May 10, 2008 Author Report Posted May 10, 2008 Ok thall work out god for the indies to seal the corners really good. Good idea Logan i might try that out on a box im building soon no way i can take credit for that, alpine said use that on all corners, about a gallon of resin and all thread and i can gain up to 6 db's the fact that i can get that stuff for free (xcept the resin) makes it awesome My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Aaron813 Posted May 10, 2008 Report Posted May 10, 2008 no way i can take credit for that, alpine said use that on all corners, about a gallon of resin and all thread and i can gain up to 6 db's the fact that i can get that stuff for free (xcept the resin) makes it awesome Someone does drywall FTW get drywall screws for free that way
loganberry Posted May 10, 2008 Author Report Posted May 10, 2008 Someone does drywall FTW get drywall screws for free that way my uncle owns the company and my parents run it....if it is home building i get alot of shit for free, lol My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
AI James Posted May 10, 2008 Report Posted May 10, 2008 can you throw a price up on the review, or is this one of those i cant tell winner post btw nice specs at 2ohms, puts it right there with the zx2500 i was thinking about running for a build i am working on for someone
