3 AB TNT 15 on Taramps md 8000.1 2ohm box
ehall8702
18 minutes ago, Gunnem said:
i just bought a MD8000 too going on two american bass XFL
upgrade from hd3000 which will be going on my mids
Alot of power, I can't wait. I had a single xfl 12 on 2k and it just ate it and kept going. 8k is kinda much but then u have headroom for rise and you don't have to set gains too high either, I'm relying on the fact that after rise I'll be up around 4 ohms and the amp won't draw crazy current to give my subs rms and a few. Put sum videos up when u get it going, definantly wanna see how brutal it gets!
23 minutes ago, Gunnem said:
ive abused the mess out of my taramps hd3k for a year so im excited to see if there will be a fire moving forward
plus 8k at 2ohm is insane
i figured if i ever do a 20k wall i will have a nice 8k for 40 midranges
My next order is either 1 or 2 taramps 440x4 for my mids ND highs...one would suffice but two would push my mids to thier full potential and they were borderline lacking with my 8s so I need to have em step up for the 15s. I was scared to get a taramps really, only hearsay about bad shit but have heard alot of positive stuff and seem good results so I figured I'd jump on it. Either gonna catch fire or beat the shit outta my 15s right?
1 hour ago, AaronT said:
Puts a class ab on your mids and highs like a normal human. Lol
Its a pet peeves of mine to have matching amps...it'll drive me nuts if they don't match! What would u reccomend then? Need about 250 x2@ 2 ohms and about 100x2 @4 ohms.
I just noticed the 440x4 has some weird speaker outputs, like the left negative and right positive share a terminal? Never seen anything like that before , maybe I'll buy 2 2 channels instead, bigger for my 4 pioneer pro 6.5s and a smaller for the 2 pro 4" tweeters....... edit, nm will not be running any if thier amps for my doors, all of em have that weird output configuration, that in itself would bother me more than not matching amps. How can there be stereo seperation with shared terminals between the channels?
Wire and terminals on the way finally.  Went 3/0 welding wire, that's equivalent of 2/0 car audio isn't it?
So basically I have 1.5/0 lol...2/0 welding will carry 450 amp so I'm sure 3/0 is close to that and I'll be running a second run as soon as I can afford it. Should be plenty to support the MD 8000 and 1 or 2 smaller amps for mids and highs
You basically have sky High 1/0 with with coarser strands that's going to be nowhere near as flexible it's going to put a little more on all your fittings you better get yourself a hydraulic crimper
Solder works.
just hit your terminals up upside down fill them with solder than while it's still hot jam your cable into it
Solder works.
I have a hammer crimp and a bolt cutters style crimper , but since it's ofc I'll solder probably. I'm pretty good at soldering, since its all copper it'll be no problem, unlike the cca shit. Coarser strands won't be an issue since I'll be running it along my frame rail , already have some double wire hold-downs. Won't be any hard bends since it'll only have to really bend once from frame then through into the cab.i have some screw in plastic things that hold wire and keep from chaffing on metal( forgot name of em but have a bag of em from a trailer I built for my old job site arc welder). I'll be running a second run soon, so should be solid wire for a LONG time. Wire is super resistant to chemicals and oils.
  • Who's Online   1 Member, 0 Anonymous, 848 Guests (See full list)
